I just overclocked my 3500+ Newcastle to 225 HTT x 11.0 mlt at 1.475 volts. The temp never got above 60C, but it would not make it all the way through 3dMark05 without rebooting automatically. Not liking the temps I was getting, I put the voltage back down to 1.35 volts and stopped the overclock. Now my system will boot into Windows and either freeze while all the splash screens are showing up (then I have to restart it manually) or just restart automatically.
Right before I overclocked, I had to take out 2 of the 4 sticks of my RAM because they would not run well together (ran at DDR200 speeds). When I took two of them out, they ran at the full DDR400, DDR450 with the overclock (checked memtest). What I'm saying is that it is possible that I may have knocked something around while I was removing my RAM because the case is pretty tight, but I don't know what it would be. I did try moving the DIMMS to the other 2 open slots and that did nothing.
What does this sound like? Even if I set all the BIOS settings for memory and CPU to default the system will do the same thing when it gets to Windows. Any ideas on what I should try?
