Specs:
A8N-SLI - 1003 BIOS - 6.39 drivers
Zalman passive chipset cooler
Corsair Twinx1024-3200C2 mem
Athlon64 3500+
Zalman 7000 series cooler
(2) BFG 6800GTs - 67.66 drivers
Turtle Beach Santa Cruz - 4193 drivers
IDE DVD-ROM
IDE DVD+-RW
(2) Seagate SATA 160Gb HD
IDE WD 40Gb HD
Antec TruePower 550
(4) 80mm case fans running on "fan only" lead from PSU
Windows XP SP1 fresh install (over and over again)
DX9c
My problem is that this system is not stable. I am testing it using 3dMark03 and 3dMark05. No problems whatsoever in 2d. In 3dMark, I get lockups, application CTDs, and system reboots.
What I've done so far:
Ran memtest for over 15 hours with no errors.
Ran MS memory diagonstics for 2+ hours with no errors
Tried a pair of MSI 6800 vid cards (non-GT, non-Ultra, no power connectors)
Tried a BFG 6600 GT
Tried nvidia video driver version 66.93, 67.66, and 71.80.
Tried nForce chipset drivers version 6.39 and 5.10
Tried BIOS 1002, 1003, 1003.007, and 1004.001
Removed sound card and drivers.
The results I've gotten are:
6600GT ran better than either one of, or both of the 6800s
Pair of 6800s runs about as well as the 6600GT
As I mentioned, no errors on memory tests
Under load, I'm getting the following power reading (multimeter readings)
12v - 11.86v and 11.84v (depending on which ground I use)
5v - 4.97v and 4.99v (depending on which gound I use)
7v - 6.87v
Immediately after crashing in 3dMark05 (CTD), I got the following readings
Video card 1 - 48 degrees C
Video card 2 - 49 degrees C (based upon reading from nVidia driver app)
CPU temp - 45 degrees C
Motherboard temp - 38 degrees C
12v - 11.712v
5v - 4.919v
3.3v - 3.232v
vCore - 1.504v (all read by Asus PC Probe, and suspect)
Does anybody have any suggestions? My original thought was that the 6800s were pulling too much power through the PCI-Express slots and that was causing the instability. I assumed this, since it seems like a power issue to me. Also, since the 6600GT seemed to run more stably than the 6800, I figured that the wimpier card used less power. So I switch to 6800GTs - since they have power connectors on the cards - thinking that would be even better. It isn't. The memory seems to run well. I'm not having temp problems. I've got enough power based on the +/- 5% theory. I'm running out of things to try.
Oh yeah. One more thing. Sometimes when the PC crashes (reboots), after restarting I get a "Widnows error reporting" thingy. Sometimes it will say that there was a problem with the GeForce 6x00 driver. Sometimes after I submit it takes me to a MS page saying that there was a device driver problem, and sometimes it says a video driver problem.
HELP!
Athlon64 3500+
IDE DVD-ROM
IDE DVD+-RW
IDE WD 40Gb HD
Antec TruePower 550
DX9c
Tried a BFG 6600 GT
7v - 6.87v
12v - 11.712v
5v - 4.919v
3.3v - 3.232v
HELP!
