Inspired by the H2O 920
Rurki
After spotting the postings two weeks back about zip tie fitting the antec/corsair closed loop coolers to various cards I decided to take the plunge. *Thank you HardOCP*
I ordered two Antec H2O 620 units for $120 - $30 in amazon reward points, $90 bucks for water cooling.
I had the various memory and mosfet heatsink left over from a previous purchase.
The photos are of the units installed in a FT02 case, running for the past few hours.
Cable management and replacement of the Corsair H50 is forthcoming; this is setup in testing mode only. (and getting rid of that damn sticking out blu-ray player)
Idle in Crossfire : 29C and 32C
Load of a 15 minute furmark : 49C
Noise - I can hear a mouse fart now, instead of two turbines in my ears.
Dont you need a shim in between the cooler and gpu? If not, im gunna do this today too!
Could you post more pics of the VRM cooling and such?
EDIT: nvm, i thought these were 7970's :(
awesome!! :D
PS: How often will you have to clean those fan filters... hmmm. they have usually been more of a nuisance to me than a benefit but as long as your temps are in check I reckon they're good.
Equalizr: Sorry yea they are 6950 and the shim is around the GPU already.
I have the unit on my desk approximately 2 feet away and I rarely see dust in the case; so the fan filter cleaning isn't an issue to me.
Idle temps now at 27 on GPU1 and 32 on GPU2.
The temp variation is due to the idle clock speeds. GPU2 is idling at 450MHz while GPU1 is at 250MHz.
thats pretty dam awesome can we getmore pics of the way you mounted them to the video cards
