Hello [H]
I'd appreciate any insight with my SFF build. I'm most concerned with heat issues in such a small case with air cooling.
Brief:
Components:
Brief:
- Primary Purpose: Linux gaming system that will be used for travel
- Primary Concern: Heat
- Primary OS: Linux (will try to run windows VM for games)
Components:
- Case:
- SilverStone RAVEN RVZ02B-W
- CPU Cooler:
- Noctua NH-L9i
- Video:
- ZOTAC GeForce GTX 1060 ZT-P10600A-10L (1060 mini)
- Drive:
- SAMSUNG 256GB 950 PRO MZ-V5P256BW (m.2 ssd)
- CPU:
- Intel Core i5-6600 6M
- MB:
- GIGABYTE G1 Gaming GA-Z170N-Gaming 5 (rev. 1.0)
- Memory:
- G.SKILL 32GB (2 x 16GB) Ripjaws V Series
- Power:
- SILVERSTONE 500W SX500-LG
- Drive:
- Kingston 480GB SSDNow V300 Series SV300S3N7A/480G (optional)
- What will you be doing with this PC?
- PC gaming. Linux OS - I'll try and run a windows VM primarily for games
- standard PC stuff (Office work/Watching streaming video/some audio editing)
- setup twitch streaming test - nothing serious
- Overclock
- None
- Budget
- Flexible, but I'd like to keep it in the $1200 Range
- Where are you?
- tampa, but I'll get items online
- What do you need?
- Listed above
- Reusing Parts
- I have a pair of SSD (Samsung 840 I can reuse)
- Motherboard features required?
- Required: Wifi - onboard sound mini-ITX
- Resolution:
- 1080p
- Space
- will travel travel so it has to fin in luggage
- Carry on limits: 9 inches x 14 inches x 22 inches (22 cm x 35 cm x 56 cm)
- I have available space for vertical setup
- Comfortable with customizing case
- no
- Sound
- Reasonably quiet - not a priority
- How Mobile
- SFF should be very mobile
- Needs to fit on carry on and I don't want to deal with water cooling at security check points
- Straps/handles are not important.
- No HDD
- OS
- Linux
- Windows VMs
- I have transferable license for windows
- When
- 2-3 weeks
