insepct before i buy the wrong thing please
Mightymouse
ok before i buy the wrong thing or anything that has something better i would like someone to inspect my specs.
ANTEC Silver Aluminum Performance 1 Series ATX Mid-Tower Case with Swiveling Front Control Panel features LED Display, Model "P160" -RETAIL
Specifications:
Case Type: Mid-Tower Case
Color: Silver
Material: 1.2mm anodized aluminum
Drive Bays: 5.25" x 4/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2xUSB2.0, Audio, IEEE1394
Power Supply: N/A
Cooling System: 1 x 120mm
Motherboard Compatibility:up to Standard ATX
Dimensions: 20" (H) x 8.1" (W) x 19.7" (D)
Special Features: Built-in washable air filter more info>
N82E16811129141
$102.00
CD/DVD Burners (RW Drives)
NEC 8X Dual Layer DVD+/-RW Drive, Model ND-2510A SVR, OEM
Specifications:
Write Speed: 2.4X Double Layer DVD+R9, 8X DVD+R, 4X DVD+RW, 8X DVD-R, 4X DVD-RW, 32X CD-R, 16X CD-RW
Read Speed: 40X CD-ROM, 12X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows XP/ 2000/ Me/ 98SE
Features: Vertical operation possible, Anti-dust seal, PC 2001 Certification, MultiRead compliant.
Packaging: OEM (No Software) more info>
N82E16827152025
$76.99
Floppy Drives
Alps Silver 3.5inch Floppy Disk Drive, Model DF354H168F, OEM
Specifications:
Capacity: 1.44MB
Average Access Time: 3 ms (track to track)
Interface: 34 Pin Standard Floppy Connector
Form: 3.5 inch
Media Type: All Standard 1.44MB & 720KB 3.5 Floppy Diskettes
Features: High reliability attained by the employment of a direct-drive motor
Packaging: OEM more info>
* (Includes FedEx Saver Shipping) N82E16821103303
$19.99
Hard Drives
Western Digital 200GB 7200RPM IDE Hard Drive, Model WD2000BB, OEM Drive Only
Specifications:
Capacity: 200GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA100
Features: Quiet Drive Technology
Manufacturer Warranty: 1 year
Packaging: OEM Drive Only more info>
N82E16822144146
$119.00
Memory (System Memory)
Kingmax 184 Pin 512MB DDR PC-3200 - OEM(2)
Specifications:
Manufacturer: Kingmax
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5
Support Voltage: 2.5V
Bandwidth: 3.2GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime
$160.00
Motherboards - AMD
**This item is NOT REFUNDABLE, exchange for same exact item only!!**
ASUS "K8N-E Deluxe" NVIDIA nForce3 Chipset Motherboard For AMD Socket 754 CPU -RETAIL
Specifications:
Supported CPU: AMD Athlon 64 Processor
Chipset: NVIDIA nForce3 250Gb
FSB: 800 MHz
RAM: 3x DIMM Supports DDR266/333/400 Max 3GB
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2x PS/2, 1x COM, 1x LPT, 8x USB2.0(Rear 4), 1x IEEE1394, 1xRJ45, 1x S/PDIF Out, Audio Ports
IDE: 2x ATA 133 up to 4 Devices
Onboard SATA/RAID: 2x SATA RAID with 0,1,0+1 by South Bridge, 2x SATA RAID with 0,1,1+0,5 by Sil 3114
Onboard Audio: Realtek ALC850(8-Ch)
Onboard LAN: 1000 BASE-T Ethernet
Onboard 1394: 2x ports by VIA VT6307
Form Factor: ATX more info>
N82E16813131498
$139.00
Power Supplies
Fortron 350W ATX12V Power Supply with 120mm Fan, P4 and AMD ready, Model "FSP350-60PN" -RETAIL
Specifications:
Type: ATX
Maximum Power: 350W
PFC: No
Power Good Signal: 100ms to 500ms
Hold-up Time: 10.0ms minimum at 230V/50Hz
Efficiency: Min 65%,Typical 70% (at full load)
Over Voltage Protection: +5V +3.3V +12V
Overload Protection: Not Specified
Input Voltage: 115/230 VAC
Input Frequency Range: 47~63 Hz
Input Current: 5A max./ 230Vrms, 50Hz
Output: +3.3V@21.2/28A; +5V@30/25.5A; -5V@0.3A; +12V@16A; -12V@0.8A; +5VSB@2.0A
MTBF: 100K hours at 25ºC
Approvals: UL, CSA, TUV, NEMKO, CB&CE more info>
N82E16817104966
$39.99
Processors
AMD Athlon 64 3000+, 512KB L2 Cache 64-bit Processor - Retail
Specifications:
Model: AMD Athlon 64 3000+
Core: Newcastle
Operating Frequency: 2GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/512K
Voltage: 1.5V
Process: 0.13 Micron
Socket: Socket 754
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info>
N82E16819103486
$179.00
Video Cards
SAPPHIRE ATI RADEON 9800 PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK
Specifications:
Chipset/Core Speed: ATI RADEON 9800 PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 4 Cables, VGA via DVI Adapter, PowerDVD, Driver CD
$198.00
subtotal
$ 1,033.97
difference between the 8mb buffer of a IDE hard drive and a SATA that is 20 dollars more?
Do you really need a floppy drive?
I'd suggest Corsair, Kingston, or Crucial RAM instead of Kingmax.
That power supply could use a few more watts, get at least a 400 for an A64 setup. That power supply also puts out a few less amps than would be recommended for your system.
Everything else looks good.
just go with ide, no big difference and an easier setup. get a floppy drive, its cheap anyway and you'll find that you'll need it every once and a while, especially with drivers such as sata.
350W is plenty for that setup, however if you plan on adding anything (like a 12V water pump) you may want to look at getting something bigger. I wouldn't bother with a floppy drive, but that's your choice. And I'd look at some different RAM, Kingston and Corsair are good brands. Proc and motherboard look great though.
