Cool Gonna try it on a older hard drive first to make sure it will work.evildre said:If you're getting a file copy error, you have a hardware problem ... check optical drive, RAM, CPU, etc. That, or you have a problem with your XP CD.
You can install an upgrade version without having the previous version installed. Boot from the upgrade version CD and begin the installation; it will ask you for the previous version's CD, at which point it will check some files (or something) and ask for the upgrade version CD again.
