just put together a new system (in sig), and i've been playing Crysis Warhead and Left4Dead. i have a Dell 24" with built-in card reader and USB hub. i hooked the monitor USB to system USB so that i could just plugin my keyboard and mouse into it instead of the system underneath my desk. i have an Apple keyboard and a Razer DeathAdder mouse.
while playing Crysis, everything is fine, smooth as butter, no problems. but, in Left4Dead, i started noticing that my input (kb/mouse) would start to lag/stutter after playing for about 15-20 mins. nothing else would stutter, FPS never dipped, game itself never lagged. i would just get input lag/stutter for about a second. then it would return to normal (if i moved the mouse during the stutter, the crosshair would jump to where it was supposed to be).
i initially thought it may be overheating, or perhaps an unstable overclock, but it made no sense as Crysis was working just fine. then i thought it may have been a bad HDD, but i ran several test and everything was fine.
i came to the conclusion that it could be the monitor's USB hub. so, i plugged the kb/mouse directly into the system, and now everything appears to be fine. no lag, no stutter.
the weirdest thing about this is that the latest time that it happened, my audio also started to lag and stutter, and eventually the game crapped out.
all is well now, but why would this happen as a result of a USB hub, and why in only one game? i don't understand. anyone care to shed some light?
P.S. the bold and color highlights are for the abridged version of this post
