A new client of mine, an attorney's office, wants me to instill some harmony into his network. A Linux elitist was his past resource, and made a bit of a mess due to his own agenda. Regardless, I hope you guys can answer a few questions for me to help me determine the next step in the route I decide to take.
About 5-6 years ago, all that existed in this office was a Dell Inspiron 1100 laptop that is now viewed as a dinosaur (it was a 2.8 GHz chip, but only 256MB RAM, which I'll upgrade to 1GB and make spin like a top). The old IT tech built a Linux server and two desktops with Ubuntu (I think 7.01) as the OS, and these are the only machines networked into the server. My client also has a new HP Vista laptop that is pretty amped up with specs.
None of the 2-3 users have become very proficient with the Linux machines, but get by as needed with Open Office. Based on an extensive interview with the partner (my client), he would like Windows on both Linux machines, and the ability to efficiently use the server for file sharing and backups.
A have a few questions that I haven't had to deal with in the past, as I've never built a server or dealt with Linux extensively:
A couple final notes:
Thanks very much for reading. Hoping to get some good input on my dilemmas.
First, I didn't pull the server (it's just in a regular case, no console) away from the wall, but I would assume that both Linux desktops are plugged into NICs in the server, and the server is connected into...I'm not sure. Does that sound logical? I doubt he has a T1, so I guess it would have to be into a modem then. I'm aware these unknowns are things I can easily find out next time I stop in there.
Anyways, we want to connect all four machines to the server, and maybe leave room for a few more, since there are two other partners upstairs that might jump on in the future. Assuming I'd like to be safe, if there are two or three machines upstairs, should I go with an 8-port router? 12? Any recommendations? And then there's the issue of how the server would tie into a router that I'm not sure of at this point.
Next is the server OS. The original tech is supposedly going to put up some walls when he finds out my client is going over his head, so I'd like to avoid contacting him if I don't need to. Since there is no console, how do I find out what is in the server via the Linux desktops? OS, RAM, HDs (I'll open it up to check the HDs).
Let's say the server OS is a Linux OS. Is it recommended that I leave it as this? What are the advantages of moving to Windows Server? And I know that depends on some other things...
That brings me to what the server will be used for. File sharing, primarily. Also, the Dell laptop is used for Quickbooks, and I want to show him how to back this up and store files to the server (as with the other machines) so I can set a backup schedule right off the server. I've discussed setting up a firewall and e-mail server on the box, but I'm going to steer clear of that, as the more I tack onto the server, the more day-to-day administration I'm going to have on my plate, and I don't have the time for more than a ~weekly visit.
I will likely run the cabling and install some plates in the drywall where network ports are necessary.
Also, they're using POP/SMTP settings for their e-mail access. Again, I'll probably leave this as is.
