Input on system before I order, ordering in an hour.
Spudsdude
Hi all, I'm looking for some input on this system before I order it in an hour. I went through a bunch of different guides and compatability info, but if somethings amiss, please let me know.
Primary Purposes: Gaming / Development
Secondary: Video Encoding (DVD)
Overclocking: Of course
Motherboard:
Abit A8N-SLI
CPU:
AMD Athlon 64 X2 3800+ 1GHz FSB Socket 939 Dual Core
Video Cards (SLI):
(2) - eVGA 256-P2-N516 Geforce 7800GT 256MB GDDR3 PCI Express x16
Memory:
G.SKILL Extreme Series 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 500 (PC 4000) Unbuffered Dual Channel Kit System Memory Model F1-4000USU2-2GBHZ
Monitor:
SCEPTRE X20G-Naga III Black 20.1" (Widescreen)
Hard Drives:
(2) - Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
Power Supply:
SILVERSTONE SST-ST60F ATX 600W Power Supply
I've already got the DVD burners, keyboard, mouse, speakers, case
if your overclockiing i would get the DFI Lanparty Motheboard. Otherwise it looks good. What are you going to be cooling with??? all that hardware heats up nicely.
for cooling.. any recommendations? I was planning on using the stock HSF, same with video cards.. case is alittle cramped, but I can fit some fans in that sucker. (120mm hole up front, 2x 80mm in back)
I also agree with the DFI recommendation, since you're overclocking. Everything else looks like it will work well together.
I have been a fan of Zalman products for air cooling. They have a great graphics card cooler and there CPU coolers are nice as well, and they are all very quiet. I would recommend going for hte DFI expert board if you are going to get aftermarket coolers cuz the space it tight between the cards on the original SLI-D or Ultra-D, from what i remember the expert has a bit more space.
i'd suggest a thermalright hs for that, along with a good cfm fan. i have a 92 mm heat controlled on my 3700+ and i've never seen temps above 45C.
if you can deal with what hassle the board throws at you, get a DFI
and why not get a 10k rmp drive for windows or loading?
