Input on first watercooling build
CoolGuy90
I am gathering and researching parts for my first watercooling built. My current specs are below:
Corsair 650D
i7 920@3.6Ghz
6GB RAM
GTX 670FTW 2GB@stock clocks
700W PSU
Crucial M4 SSD
So far here is what I have in mind:
Pump/Res: XSPC Dual 5.25" Bay Clear Reservoir - w/ D5 Variant Pump
CPU waterblock: XSPC Raystorm
GPU waterblock: Heatkiller Bi-Nickel
Radiators: XSPC EX240, EX120 in push configuration
Fans: Swiftech Helix 120MM
Fittings: Bitspower 3/8 x 5/8 compression
Fluid: Distilled water + biocide
Tubing: Primoflex PRO LRT
As far as layout, the EX240 will be mounted on top, and EX120 mounted in rear. Case cooling wise I have a 200MM in front as intake. The only thing i'm worried about is if a 240MM rad and a 120MM rad will be sufficient enough to cool my overclocked i7 and GTX 670FTW. I'm gonna leave the 670 at stock clocks and may try and get to 3.8GHz on my i7.
Please let me know of any suggestions, more than happy to take input.
