Input on drives for a 4-8TB RAID5?
Looking to update my 1.5TB 3x750GB Seagate 7200.11 RAID5 to a 4-8TB RAID5. I have 6 total slots for drives. I will be using a Dell PERC H700 so I can use 6GB SATA III.
I am more concerned about speed so I am thinking at least 4 spindles. 4TB would be more than enough, but not opposed to more space if there are drives that are good bang for the buck.
I was looking at getting 4x1.5TB Western Digital Black drives. Any other drives I should be looking at? Other drives that work well in a RAID5?
Thanks for the input all!
WDC black drives are not compatible with hardware raid. I recommend hitachi drives for that. 7k3000s if you need speed. 5k3000s for a media center or backup application where random performance is not at all important. Search this forum for TLER for the reason.
Thanks for the input on that. I'm glad I posted! Are the Hitachi desktop or enterprise drives the way to go?
I think I will revise my plan and look at the 7K3000 1.5TB or 2TB drives.
On Amazon the 1.5TB and 2TB are the same price....$129.99. I think I'll go with 4x2TB.
You state speed would be a possible issue. How much throughput are you looking for? The SATA3 connection is not really doing to help with non-SSD drives (they don't have enough throughput). You may want to look at Samsung 2TB drives. I think the Egg has them for sale for $99+FS.
Not sure what you mean by "state speed". I know the drives won't even hit the limit of SATA 2 but I went with the H700 since I am looking to have a controller that works in my PowerEdge 1900 so it reports back to the Dell management tools. The H700 also allows me to have one big container.
I figure I may as well get the latest and greatest. I can't imagine the price difference between SATA 2 and SATA 3 is very much.
The Hitachi Deskstar 3.5" 2TB 7200RPM SATA III 32MB Cache Internal Hard Drive 0S02861 is $129.99 on Amazon and NewEgg. I'm in California so I pay tax at NewEgg.
I did read that the Deskstar drives run hot and these are going to be stacked on top of each other in a server. Maybe I should look at the Samsung EcoGreen? I think I might want to stick with 7200RPM drives for this project....
Drives don't run hot. Different drives migth require different amounts of air flow, but that is a different issue.
I meant "you stated speed..."
Gotcha. I know I won't even max SATA 2.....but already have the card....just need to find the drives. The 3 Seagates I have in there right now have been fine since day one. I just need more space and would like some more speed as well!
