That monitor has a Scaler, so it would probably be between 15ms to 20ms, you can google check for qnix 2710 scaler and would probably be the same for that screen, the Korean monitors that are actually fast does not have scaler so typically are DVI.D only, i used to have one of those bur for fast paced games it was a blur fest cause the pixel response of the panel.
