Hexus0 said:I don't see why you would go with this rad, I read the other thread and you want to run it passive, but where exactly can you attach it to your case?
Heres a worklog where a guy used those rads, he hasn't finished yet butyou might be able to talk to him about it: http://hardforum.com/showthread.php?t=1006970&page=3&pp=40
If I were you, I'd go for an easy setup with a BIPIII or the ThermoChill PA (or HE forgot which ones use quieter fans) and just use really quiet fans...
Hexus0 said:Looking good, are you going to post a worklog? Did you decide on blocks you were going with?
Bbq said:I doubt the inno will do it. Unless you get the booster, or another radiator, it will heat up faster than a prescott.
