SevenWords
- Sep 8, 2006
I just got all the parts for my first W/C loop and have been reading up alot on doing a first cleaning and then setting it all up externally and running for 24 hours to leak test. I'm not really sure how to do this since I'm planning on using non-conductive fluid in my loop, and doing a leak test with distilled water would pretty much negate the non-conductive fluid once I put in the loop when installed correct? Also, since I'm using 7/16" tubing on 1/2" barbs, I've heard it's a PITA to get off once it's on the barbs, so doing a complete teardown of my setup after leak testing could suck. Is it ok to do your leak test with everything setup (CPU block mounted, GPU block mounted) as long as you just jumper the PSU and have no other power lines connected to the MB or anything else?
Sorry for all the noob questions, just trying to get my first time watercooling right.
