inFusion by Smasher [Scratch Build]
Smasher
Now yes!
inFusion​
The project infusion is a Scratch Build case that will be builded from the beginning with different types of materials: Acrylic, Metal and Wood.
Have a unique shape and design, containing in it a powerful hardware.
Have a watercooling (Corsair H50) modified for this project.
The aesthetic is warm hug, with around 183 hours dedicated solely and exclusively to this design.
These will be the base material will be used:
Samples of acrylic, acrylic tubes, and sheets of old cases.
With this cover of old cabinet, the main structure will be built.
Based on a test piece made of cardboard, the cuts are marked.
Starting!
Filing the edges and sand the paint to make the raw metal.
With this piece semi finished, we will build the front, which will house the hard disk and DVD lectograbadora.
While I Twitcam
With the heat gun to bend the acrylic we have left to 90 °.
Now the sides of this piece, also bent with the heat gun.
Las piezas se pegan con cloroformo industrial, diluido con acrilico para darle una consistencia espesa y que no se evapore tan rapido.
The rough edges that will be sanded.
Más de la estructura principal.
I had the problem that the acrylic is encompassed by a lot of heat, so should replace this piece.
Now yes!
The "cap" where under DVD.
Adding an acrylic to add rigidity.
Through which pass the wires from the HDD and DVD.
Submission:
From one side of cabinet manufacture it a holder for the source:
Screws and mother presented.
VGA:
photobucket links dont work
Edit: Working now, thnx for fixing them.
Well after a while I return with much progress.
I was at an event, in Loki Custom Tech stand, exposing White Timantti, photos of the event here:
Web
In this joined Kingston as Sponsor, providing a HyperX 2x4GB DDR3
and 110gb.
We continue to progress, stand to tighten and not have to go with glue:
And set the psu support:
Support for the base:
Cut cut cut
PSU
"Knockouts" where they will spend the sata and power
Ventilation to go with metal mesh
Now we start with the "box" of the motherboard
This is a side project, will modding on these pc's, can follow the project on
www.facebook.com/SmashModding
Sides
Small window on a single pass of the power cables
Old cabinet veneer, thick as a good basis for
Presenting
Support for HDD's
Re-do media
i/o Panel
Window-mesh
Support structure
Good and so is at the moment, I hope your opinions!
Well I have a few developments
I worked all part of the radiator
And went back to do the HDD bracket because on the other, the bottom had no room for the cables:
And I started a small reservoir for H50, lack seal:
regards!
After a while of modding, progress:
Modification "box" of the PSU:
And finally paint!
Ready to paint
Was something like:
VGA Cover
Fans:
Painting on the VGA:
PSU Sleeving:
This source is unique in this topic:
Which would not let me do sleeving 1x1, cut extensions.
Santi approves the project!
Scratch Build finished paint job
As we continue with the cables:
inFusionSmasher151jpg
Starts assembly!
And the mini reservoir of H50:
In a little while final photos!
