Has anyone seen this error message before? I get it all the time, requiring me to click "Ok" 2-6 times before it stops reappearing. Then, after a little break, it'll start again. It doesn't show up in my process manager so I can't figure out where it's coming from. Thanks for any help.
Plus, if it was a genuine windows error message box, the buttons would be skinned with the royal theme like the border of that window.
I'll tell you 1 thing, that isn't a windows error box! Thats a "Your computer has been infected, click this button so we can infect it some more" error box.
or better yet, back up your data, format, install XP (with all updates), a firewall, anti-virus, spy-bot, ad-aware, and ccleaner.
According to the last post in this thread (page 2) it may be a conflict between Starforce and a Nero DirectShow filter: http://translate.google.com/transla...ewTopic_14927_4_Error.html&hl=en&lr=&safe=off The solution given is to rename the file "C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax" to NeVideo.ax1
