Infinity + DS3 Question
Glyphic
So, I got my Infinity in today, but I'm not sure if the cooler is gonna clear the caps just above the cpu socket. Can anyone else with a ds3+ infinity help me out with this?
EDIT: OK, so I got it on there, cleared everything, it was a pain in the ass getting in on and secure, had to remove my ram, video card and everything. Now my question is, how should i mount the fan? should It blow air onto it so my rear case fan will take the air off?
alright so,
___________
|psu |
|^(CPU) |
|^ exhaust |
| | 80mm intake
___________|80mm intake
no worries, have this setup already. Your good to go!
So, how about I figure it would be a good idea to remove the mobo tray and install it the scythe right? Well, After I got everything all in there and all, I discovered that it was too tall for it to slide back into the case :mad: :mad: :mad: Had to remove it, put the tray in, remove my ram and everything again, and then remove my psu in order to get the damned thing back in there. spent a good hour, but when I booted my system up I was AMAZED. Idling at at 29-32, its bouncing around, but I'm already oced at 2.4ghz so this is awesome. I think I might have put a little too much as5 on there, I checked and it was kinda touching the little cpu holder a little. Anyways, I started running ORTHOS, and full load is only 40C :eek: I'm very happy that I got this, I fully reccomend this to everyone!
Question: I have a case fan and a 40mm fan. They both use 3 pin connectors but the DS3 only has 2 connectors. One for the cpu, and the other for the sys fan. I bought a 40mm fan for my northbridge. Both of these fans have 3 wires, so I'm wondering what do I do with the yellow wire when I mod it to a molex connector?
nothing! the yellow wire is for RPM monitoring :)
Ok so, this causes a new problem, the fan spins too fast. I actually have a rheostat, and I tried using it, but it still moved to fast in order for me to use it, so my northbridge is getting around 60c, and is actually warming up my cpu a little.
Pics! ( Excuse the shitty camera)
Northbridge is DAMN tight in there
Even tighter is my ram to the scythe's fan.
