skzyer said:For a few months my friends computer has been getting a blue screen which reads
Driver is in an Infinite loop ati2dvag
Now it wont even go to windows, and the monitor even says "No Signal"
any ideas?
ATi Customer Service said:We have responded to your issue.
Solution: The infinite loop error can be caused by a number of system software settings or hardware failures...
"DEVICE DRIVER is STUCK IN INFINITE LOOP" or VPU Recover errors in Windows XP
This issue affects the following system configurations:
Windows XP
Any ATI display card
Based on our experience, the error "The drivers for the display adapter got stuck in an INFINITE LOOP" is a result of a system communication mishap...
This issue can occur using any motherboard or graphics chipset along with the Windows XP Operating system. It appears that in most cases this problem is due to a BIOS setting, specifically options affecting the way the RAM, CPU and graphics card communicate with XP and DirectX. Improper timing settings can result in system lock ups or random system reboots.
This issue also affects different makes and models of video cards from various manufacturers.
