inexpensive PoE switch?
FLECOM
Modder(ator) & [H]ardest Folder Evar
Staff member
I am looking for an inexpensive PoE switch to put some VoIP phones and Cisco access points on... anyone have any suggestions?
Without knowing how many devices and how much power each one requires it's fairly hard to give an accurate recommendation. Also, there are a couple flavors of PoE out there depending on how old the devices are so you'll have to factor in that as well.
Hey Flecom - I have used the Netgear units, usually come in a 8 port with 4 ports POE.
8 port with 4 being POE - http://www.newegg.com/Product/Produ...2152&cm_re=netgear_poe-_-33-122-152-_-Product
8 port 8 POE -http://www.newegg.com/Product/Product.aspx?Item=N82E16833122154&cm_re=netgear_poe-_-33-122-154-_-Product
Dont know if you need even cheaper but Trendnet has a few cheaper models, haven't used the switches before but have used some of the Fiber to Cat5 converters - http://www.newegg.com/Product/Produ...287&cm_re=trendnet_poe-_-33-156-287-_-Product
I have used the Dell POE 48 port switches, they are pretty inexpensive and plenty reliable
fair enough
I need about 8~ PoE ports
I think the PoE flavors are going to be an issue as I have older 7961 cisco phones and newer Polycom phones... Access points are an 1131AG and a 1231AG
what does inexpensive mean to you?
the Dell POE i haven't used are suppose to be nice, those other models that i posted have worked good but i use them in higher end homes
prefer <$100
this is just for home and for phones and wifi, I don't need gigabit or anything fancy... just has to work
I have a cisco 3524 but it does not work with the polycom phones... just the cisco phones
might just have to use injectors for those I guess :(
i think anything will be over 100 new. that trendnet should work fine, look on ebay maybe, or a used netgear as i posted.
injectors are fine if you have them.
how about the HP 2600 PoE switch? anyone used one of those?
