inexpensive case/psu recommendations
geepondy
Putting together a Athlon 6000 X2 system and other spare parts for gf. What is an inexpensive case with PSU or the two separate, recommendations. No lighted or clear side panels and I'm looking to build on the cheap but want PSU with reasonable confidence will not die right away. Not a power system at all, although I will be putting in 7600GT video card but I understand this is not a power hungry card. Thanks.
heres one, case
http://www.newegg.com/Product/Product.aspx?Item=N82E1681114606
cheapo case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147074
psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
im sure some cheaper deals. only spent a few minutes looking.
i like nzxt and coolermaster, and antec cases a lot. but you can find cheaper. if u got a tiger or compusa by u, u can always find clearance cases there usually. u can use a generic case just fine, and then buy a quality psu... keep in mind even the best brand names have lemons now and then, but generally they work pretty well. i gotta get some sleep//
