Incredibly stupid, embarrassing, ram addition question...
You will be fine. You may have to downclock it to 1333 if your CPU can't handle 4 sticks at those speeds.
Buying multiple kits instead of one kit with several matched sticks is sufficient 99.99% of the time. Buying one kit with several large sticks just makes sure that all the sticks are guaranteed to work together.
I bought 2 sets to up my old machine to 16gb and had no issues.
On this machine, I bought a 16gb kit since it was cheaper than buying another 8gb kit.
Brother was building a machine with 8gb, so he got me the 16gb kit, I gave him my 8 and paid the $30 difference.
According to his signature, he has Ivy Bridge, which officially supports DDR3-1600. He'll be just fine running all four slots at an officially supported speed.
Should run without problems as long as you dont mix and match with different sticks.
It's the same exact set (i.e. same link, same product/item #) that i ordered last year.
It's scheduled to come in Thursday. Can't wait to pop them in there and not really take advantage of it.
Should be fine. I have the 16GB (4x4GB) kit of that memory running on my 3770K using the XMP profile (9-9-9-24-2T @ 1.5V DDR3-1600). Note that when running 4 sticks it seems to require 2T command rate instead of 1T. I haven't even bothered trying 1T since the difference is minimal for my needs.
IB runs dual channel, not quad channel. Technically the RAM doesn't have to all match. You'll be fine.
Haha, missed this the first time I read the post. I've been thinking about trying an 8GB RAM drive to see how fast I can get games to load, unfortunately BF3 is what I want to test with and it's too big. Might try TF2.
They have CAS 8 latency RAM of the same line. Its what im using and its great. Can even do 1T cmd rate.
