Incredibly low 3dsmax score...
Soapy5
okay, i just downloaded 3dmark06 out of curiosity of how my comp stood up to the rest.
my specs are (according to 3dmark):
AMD Athlon(tm) 64 Processor 4000+
Architecture 64-bit
Internal Clock 2.4 GHz
External Clock 200.0 MHz
Caches
Level 1 128 KB
Level 1 128 KB
Level 2 1 MB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.2180
Display Device 1/1
NVIDIA GeForce 7800 GTX Driver 9.1.3.1
Total Local Video Memory 256 MB
Total Local Texture Memory 626 MB
AGP Aperture Size 0 B
Driver File nv4_disp.dll
Driver Version 9.1.3.1
Driver Date 6-1-2006
Driver WHQL Certified true
Max Texture Width 4096 px
Max Texture Height 4096 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 3.0
Pixel Shader Version 3.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 1.3 GHz
VGA Core Clock 491.4 MHz
PCI
Name NVIDIA GeForce 7800 GTX
Vendor ID 0x10de
Device ID 0x0091
SubSystem ID 0x21811682
Revision ID 0x00a1
Sound Device 1/1
Creative Audigy Audio Processor (WDM) Driver 5.12.1.442
Description SB Audigy 2 ZS Audio [8000]
Manufacturer Creative Technology, Ltd.
Driver File ctaud2k.sys
Driver Version 5.12.1.442
Driver Date 11-18-2003
Max Supported 3D Hardware Sounds 64
HD Audio Support false
EAX Support Supported
PCI
Name Creative Audigy Audio Processor (WDM)
Vendor ID 0x1102
Device ID 0x0004
SubSystem ID 0x20021102
Revision ID 0x0004
Memory Info
Total Physical Memory 2.00 GB
Free Physical Memory 1.58 GB
Total Pagefile Memory 6.78 GB
Free Pagefile Memory 6.53 GB
Memory Array 1/1
Max Module Capacity 16 MB
Location System Board
Use System
Supported Speeds -
Supported Types -
Supported Voltages -
Memory Slot 1/4
Installed Enabled Size 0 B
Form Factor DIMM
Frequency 200.0 MHz
Slot A0 [Bank0/1]
Type Details -
Enabled Size 0 B
Total Bit Width 64 b
Data Bit Width 64 b
Memory Slot 2/4
Form Factor DIMM
Frequency 200.0 MHz
Slot A1 [Bank2/3]
Type Details -
Enabled Size 0 B
Data Bit Width 64 b
Memory Slot 3/4
Form Factor DIMM
Frequency 200.0 MHz
Slot A2 [Bank4/5]
Type Details -
Enabled Size 0 B
Data Bit Width 64 b
Memory Slot 4/4
Form Factor DIMM
Frequency 200.0 MHz
Slot A3 [Bank6/7]
Type Details -
Enabled Size 0 B
Data Bit Width 64 b
Motherboard Info
Supported Slot Types ISA, PCI, PCI Express
Manufacturer Gigabyte Technology Co., Ltd.
Model GA-K8N Ultra-9
BIOS Vendor Award Software International, Inc.
BIOS Version F6
BIOS Release Date 12/05/2005
BIOS Properties Plug and Play, Flash
AGP
Available Rate 0x00000000
Selected Rate 0x00000000
Aperture Size 0 B
Sideband Addressing -
Fast Write -
whew thats alot of specs. anyway, id like to (in defense of my prrrecious computer) state that so far ive had no graphical problems whatsoever. i havent played any extremely-graphic intensive games lately, but i can say that i can play halflife2/counter strike with everything maxed at 1240 x 1024, including HL 2: lost coast with hdr.
anyway, my 3dmark score was..... 3309.
i checked what systems like my own got, and the scores were around double mine.
so my question is: does my computer not like 3dmark, do i need to (re)install some drivers before running 3dmark?
speaking of which, i have noticed my computer being a lil sluggish lately, and ive been thinking of reinstalling xp again...
try reinstalling XP again, and make sure you have updated drivers...
...other than that, i don't have much...
Wow my very aging systems have come close to that mark. I would try a driver cleaner from 3dguru or guru3d.com whatever the addy is and then install updated drivers. Also ensure that all your drivers for your motherboard are loaded...
Sunin
title is confusing (3dsmax).
dude! it's friday night, stop thinking about work.
lol, just caught that. I'll try reinstalling xp, cause my comps been a bit sluggish lately; hope that will fix it...
