Increasing power
MirageMobile
I have a TP-II 480w PSU with "fan only" connectors.
My case is an Antec P180 with 3 120mm trispeed antec fans.
Not even one of the 120mm fans runs on a "fan only" conntector. Is there a way to increase power to these connectors so that i am not taking up other power connectors?
yeah... i have those. depressing. Supposedly they're temp controlled by the PSU. The only thing you can do is run fewer fans on those connectors, and even that has limited effect.
IMHO, they're somewhat useless without more power or some kind of trim control.
yea i would say when i have one 120mm fan plugged into one "fan only" connector it runs maybe 150+ rpm. Also, it does not even begin to spin without a push start from me.
