Sep 10, 2009 #1 D Dutch Limp Gawd Joined Aug 10, 2004 Messages 268 I just got a WHS up and running and notice that my network transfer speed is only 10MB/sec. The WHS is on IP35 Pro with an E6750. I installed the latest LAN drivers from realtek. What things can I look at to increase the speed?
Sep 10, 2009 #2 T tgrimley Limp Gawd Joined May 1, 2006 Messages 311 More details about the transfer? from what to what? what hard disks, what adapters, controllers? 10MB/s is 100mbit speed, is your link running at 1gbit speeds? are both adapters? are the hubs/switches?
Sep 10, 2009 #3 M MrWizard6600 Supreme [H]ardness Joined Jan 15, 2006 Messages 5,791 edit: nevermind Last edited: Sep 10, 2009
Sep 10, 2009 #4 T tgrimley Limp Gawd Joined May 1, 2006 Messages 311 ha nevermind too.. mistakenly thought post #3 was the OP
Sep 10, 2009 #5 B Brak710 [H]ard|Gawd 2FA Joined Oct 27, 2008 Messages 1,424 Yeah, I'd recommend taking a look at everything in between for a bottleneck. You might have some Gigabit hardware misconfigured or acting up.
Sep 10, 2009 #6 F Forceman [H]F Junkie Joined Aug 7, 2005 Messages 9,243 I had a problem with my WHS running at 100 speeds even though it was on a gigabit network - updated the NIC drivers and the problem went away - what driver set from Realtek did you install, Server 2003?
Sep 10, 2009 #7 D Dutch Limp Gawd Joined Aug 10, 2004 Messages 268 Too retarded, my switch on the computer is indeed only 100 Mbit while the WHS is hooked up to the WRT54GL. Thanks for making me check the obvious.
