Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a Shuttle SB75G2 that I've modded just a little. I removed the fan grill on the back (using a dermal tool) and replaced the stock fan on the I.C.E heat-pipe heat-sink with 2 Panaflo M1A's, one on the outside of the case and one in the factory fan holder on the inside. You will also want to remove the factory thermal interface material with something better like Artic Silver 5. I also made a "blow" hole in the top for a low profile 80x15 fan (used this one: http://www.newegg.com/app/ViewProductDesc.asp?description=35-118-212&depa=0).
i never really had any temp issues with my shuttle (sn85g4 w/ 3400+, 6800gt, 2xhdd) until i put it in an area where there was no open air. temps got really bad and hover at around 60*C on the processor while just watching a vid or listening to music. in an open air environment temps were better, hovering at around 40*C.
by closed air i mean it's basically sitting in a box with one side open.
40$fan as loud as a person talking 24/7?? no thx lol hehe, i thought out some stuff, wire mesh side, and blow hole on top, giving direct cool air to the heatpipe/heatsinks. and wiremesh side case lets vid card get cool air from outside case with ease.
I've seen 'em on ebay as well, tho don't think you'd save much there. You could mod your own case with "modder's mesh", but in this case, it might be easier (and cheaper as well, if you consider labor) to bite the bullet and buy the factory made mod.
