increase voltage on 7800GTX
polive
I seem to be stuck at 470 core on my GTX. For CPUs, increasing the voltage can get you past stability problems on overclocking, provided the temp is low enough.
Can you increase the voltage on the GPU for a similar overclock stability without artifacting?
