Incorrect Voltage readings?
spartus4
I have an EVGA 790i SLI FTW and when I check the voltages (+12V) they are really messed up. Speedfan, Everest, and Dr. Hardware all say that I have a Voltage on the +12V of around 5.86V. I find this hard to believe for the fact that the system is completely stable. In the bios the reading is 12.12V. I have run two instances of Orthos Prime 95 (Quad Core) and I play Fallout 3 and Crysis Warhead. I have read that with this reading the system should freak out. My question is: Should I be concerned about the readings in the monitoring software or should I be more focused on the reading in the Bios.
Update: I sent an email to thermaltake and they told me how to check the +12V with a multimeter. Turns out that it is just fine running at 12.01V. I have seen other people having this same problem. I guess EVGA is using junk Winbond chips.
Everyone uses junk Winbond chips (or something similar). Never trust software readings. If you're ever curious about your voltages, the only way to get a halfway accurate reading is with a multimeter. Anything else is just conjecture.
