I currently have a setup with a 10/100 router/switch at the top level, connected to a gigabit switch, to which my computer and HTPC are connected. When I transfer files, it is almost always files that are several hundred MB to a couple GB each (basically, not a bunch of tiny files).
Sometimes my speeds are sustained at 80+ MB/sec, and the lowest "normal" sustained speeds I see are in the 30-40 MB/sec range. Maybe 25-30% of the time, though, I transfer at around 11 MB/sec, which is painful when I know I could be transferring files much more quickly.
What, exactly, is going on here? I know that 11 MB/sec is the upper limit for 100 mbit connections, indicating that the connection is sometimes limited to 100 mbit/sec. Coincidentally, this is the maximum speed on the router. I don't know very much about networking, but is it possible that my data normally just transfers through the gigabit switch, but sometimes goes through the router?
