EDIT: Got it working now.
Just threw a new Seagate Ironwolf 10TB drive into this enclosure and plugged it in and turned it on.
The power LED on the enclosure isn't on and the HDD doesn't feel like it's turned on and I never noticed my computer installing any software.
When I go to "Safely Remove Hardware and Eject Media" I can see "Eject ASM1153E" which is the enclosure.
But the HDD isn't added to This PC > Devices and drives.
Opened "Disk Management" and got this pop up - "Initialize Disk > You must initialize a disk before Logical Disk Manager can access it." It shows as: Disk 3.
I can select "Master Boot Record" or "GUID Partition Table."
I'm thinking I just select GUID and hit OK, but not sure?
When I load Device Manager and look at "Storage controllers" I can see 2x USB Attached ASCI Mass Storage Device saying: Windows cannot use this hardware device because it has been prepared for safe removal, but it has not been removed from the computer." Not sure if this has anything to do with my issue.
Safely Ejected ASM1153E - turned it off / unplugged and re-plugged / turned back on and now I see a green light on the enclosure and the drive feels like it's on, but still no drive added to Devices and drives.
I'm guessing I need to do something in Disk Management? Upon further investigation, "Disk 3" looks like It's the 10 TB HDD. So I assume I select GUID Partition Table?
