Zenzrevenge
- Sep 11, 2006
Hello,
So I was having problems with getting my vid card to work and it was suggested I just reformat. I was hesitant to due this but after everything else failed I decided what the heck.
So I back up my files on an external drive and I change my bios to boot from cd rom. I put my disc in and restart.
Everything works like it is suppose to I delete my partitions and start the installation. Basically everything works fine and I get to the part where it needs to restart and it says when it restarts set up will continue. Well when it restarts set up does not continue set up starts over. I have tried everything i can think of, i've changed it so it will try to boot up on the harddrive, left it at the cd rom. NOTHING works if I have it start up with the hd it just gives me an error saying window failed to launch and if I have it start up with the cd rom it just starts over.
I am in dire straights at least before i had a computer that worked sure the vid card didn't but I could do everything else. Now I am DOA>
Any ideas?
Any ideas?
