In house Render Farm/Render Station
Brashen
Hey [H],
I'm an art director at an AD agency and one of my many hats is 3d modeller and motion graphics. We need to build an inhouse solution for rendering 3d stills and animations and videos from AE.
Rendering 3d and 2d Animations/Stills (3dsmax, C4D, Houdini, After Effects)
$4000 T&S not included
Lebanon Beirut. But we have a supplier that provides us with the items.
CPU , GPU, MB, RAMs, Case, Cooling Solution,
6) Will you be overclocking?
No
not required
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
As long as its usable as a standalone workstation.
No
What do your current workstations look like? How familiar are you with DBR?
Distributed computing / setting up a home render farm is pretty far from my forte, sadly.
Our 3d guys at work use a cluster of these for their rendering needs. (I recommended the rackmount version, but they insisted on the goofy form factor versions. w/e.) I don't know anything about the software configuration though.
How long are things taking to render right now? Would you be better off just building out better workstations for everyone and rendering locally? I've been pleasantly surprised by my 5+ year old L5520's for rendering tasks.
Have you looked at GPU Rendering software?
Is your current bottleneck straight up CPU? What type of infrastructure do you have? Do you have a fast NAS/SAN as a shared resource point for distributed renders?
The Distributed Computing part of this forum might be able to help more, as can the Digital Artwerk section. You're more likely to run into folks who have run into this kinda thing over there.
Do you have a server closet? Have you considered something like this?
That'd help logistics tremendously over having a bunch of whiteboxes cluttering up a backroom.
Or are you intending on using these render machines as workstations?
Do you have a virtualized backend? You might be able to spin up VMs for rendering purposes.
I have two Ubuntu VMs (one per hypervisor) that have access to 14-cores/20GB memory for rendering in Blender, and they work wonderfully.
