In-game or video card control panel settings?
IceWindus
Question thats been bothering me since I got my 6800GT. What has been the proven better way to enforce settings on your games in regards to AF, AA, VSYNC, Refresh rate,ect..ect..? Is it better to do it in game or with the video cards driver control panel and what gain or loss has been found on either or? I found on my 9800pro I just left all my settings the same no matter what game I was playing but then I heard people say you get better framerates if you let the game do the settings for you, especially Doom 3
Whats some incite into this?
In-Game if the options are there
otherwise force it via the driver control panel
BTW in DOOM 3 when you enable High Quality 8XAF is automatically enabled if you have the control panel set to application preference
You want to use in-game settings first and then if that setting is not available in-game then force it through the CP. AA and AF should be be set in-game when available because especially with AF it applies it the way the game developer intended.
ATI cards actually have lower quality anisotropic filtering when enabled through the CP because its more heavily optimized. Enabling it in-game will have a little better quality but lower frame rates.
I personally dont use V-sync because i dont think its necessary with a good CRT and it just hurts performance. If you can limit the fps in-game then thats the best way to cap your frame rate. Morrowind allows me to cap the fps in the Morrowind.ini file.
