In a pinch! Please help.
mrmemnoch
Heres my system:
OCZ 520W SLI
FX-53 940 PIN
200 Gig Sata seagate
1 gig stick Corsair XMS registered mem
Sapphire GTO2
Foxconn NFPIK8AA Motherboard
2 Optical Drives
Heres My problem:
I had an OCZ power stream(non SLI) and a APC surge protector. When I turned on the powersupply the surger protector made a shrill noise and everything shut down.(There was no storm) Well after various testing I found that the PSU was fried so I bought the one listed above. So I hooked everything up and... All the fans, Hard drives, Optical drives, floppy drives, and video card fan boot. The problem is that I am getting no signal to my monitor, nothing on the I/O panel is working including my mouse, keyboard, and LAN. The monitor works, I tested it on a friends computer along with the other periphrials(keyboard, mouse). Well I have a finals this week and was hoping to use my own computer. Any advice at all would be appreciated.
Edit: I have tried clearing the CMOS with motherboard jumpers(no result).
If you haven't fix your problem, try disconnecting everything but the power, CPU and HSF, RAM, and video card (unless you have onboard video, then remove the video card). If the machine gives you the same results, try the video card/processor/memory in another computer to see what's causing the problem.
if you can get your hands on a spare vid card, you might want to put that into the case. if you're getting no video response, there's the possibility that your agp slot might have burnt out. if you can't get a response with that spare vid card, then get your hands on a pci vid card. if the pci vid card works, there's a good chance the problem has to do with your agp slot.
