howdy
i'm looking to improve to cooling performace of my water loop. reason being i've decided to skip upgrading to SB (adopting a wait a see till BD / IB arrives) and partly due to these threads.
-[Review] Triple Radiators V2
http://hardforum.com/showthread.php?t=1467444
-PUSH or PULL for single 120mm radiator exhaust fan?
http://hardforum.com/showthread.php?t=1537776
after reading the 'Triple Radiators V2' topic i realised my loop kinda sucks (have a 10 to 15 degree delta btw ambient temp and idle on q6600 cores).
Note: My q6600 is clocked @ 3.6GHz (400x9) on vcore 1.4v. all power management feats. turned on. idle clocks @ 2.4Ghz (400x6)
also i'm not sure if i should have my rad fans in a push or pull orientation after reading 'PUSH or PULL for single 120mm radiator exhaust fan' thread.
the parts in my loop (in sig) all on 1/2 ID loop tubing;
-swiftech MCP 655 pump >
-swiftech MCR360 radiator (w- 3x120mm NBlocker 1800rpm fans @ 1400rpm, push config) >
-Apogee GTX CPU block >
-MCW30 block (SB) >
-MCW30 block (NB) >
-Dual 5 1/4 bay res >
See pics below (i know, not exactly pretty at the moment...)
Left side of case;
Right side of case;
Right side (rear top);
in the 'PUSH or PULL' thread a suggestion was made to install shrouds between the fans and radiator. i have 4 or 5 thermaltake tt-1225 120mm fans (never used, came with the case) which i can gut for this.
i couldn't find much in the way of info for the TT fans apart from here;
http://www.hardwarecanucks.com/foru...rmaltake-big-typhoon-cpu-cooler-review-5.html
they seem to think the fan is ok. perhaps it may be better to use them conjunction with my Noise Blockers' in a push-pull config rather than gut them for shrouds...
in anycase i'm worried about introducing more noise. i recently replaced the rad fans. the old fans were Scythe Kaze 2000rpm 38mm fans and they were a little too loud even when reduced to 1300/1400 rpm.
anyway any suggestions would be great.
cheers.
-MCW30 block (SB) >
-MCW30 block (NB) >
Left side of case;
Right side of case;
cheers.
