Improving Bluetooth Connectivity
bigdogchris
I'm testing a couple USB Bluetooth receivers for Windows 10. The issue is the range is horrible on one and the quality is bad on another. The one I have with an antenna has a longer range but has popping sounds no matter where you are at (even right in front of it). The one with shorter range sounds fantastic, but doesn't have the range I need.
The devices use Realtek chipsets and I'm using the latest drivers available on the website.
Any tips on how to clear up the quality?
