impossible case?
fightingfi
Im looking for a mid to full size case must hold up to 6 internal hdd's, would like to have 2, 120mm fans in front, 1 rear and top fan also BUT id like it for under 60 bucks...:confused:
Not trying to be rude Sir but wheres the place to mount the fans in front its MY fault i forgot to mention open or grilled in the front to push air thru the case of the hdd's once againMY FAULT for not being more Specific Im sorry........
The gap around the plastic front panel is vented, and the fans mount behind the front panel. If you want a grill, see if you can grab the Source 220, rather then the 210.
