Important: I need feedback from FI-90HD users
Dillusion
I'm doing research into the board deaths and I need your guys help big time. If you could tell me this info it would be great:
Board working: Yes/No
Ram Company:
Ram Model #:
Ram PCB: Brainpower or JEDEC Standard
Ram IC's: Micron D9, Elpida, Etc (Check the RAM list to see, or if you know for SURE)
Ram Stock Voltage:
Ram Voltage as you use it 24/7:
Ram Voltage MAX you've used EVER:
Please guys, I have an idea of what's going on, but I need to confirm it, thanks.
Board working: Yes
Ram Company: Teamgroup
Ram Model #: PC6400 4-4-4-10
Ram PCB: Brainpower
Ram IC's: Micron D9
Ram Stock Voltage: 1.8-2.0
Ram Voltage as you use it 24/7: 2.0
Ram Voltage MAX you've used EVER: 2.0
Board working:
Ram Company: GEIL
Ram Model #: GX22GB6400UDCA=
Ram PCB:
Ram IC's:
Ram Stock Voltage: 1.9V - 2.4V
ill tell you tuesday when my ram comes in :)
how can i check all this info? besides whats on the package ;)
Board working: Yes
Ram Company: Corsair
Ram Model #: TWIN2X2048-6400C4
Ram PCB: no idea
Ram IC's: not sure which revision i got but i got it last weekend, either Infineon C or Elpida H according to ramlist for rev 4.x and 5.1
Ram Stock Voltage: 2.1v
Ram Voltage as you use it 24/7: 2.1v
Ram Voltage MAX you've used EVER: 2.1v
Does anyone have a link to that ram list? I'm sure a few people would need to use it in order to find their IC's....
i think mine just died... turned it off, then turned it on and wont post. dissconnected all the drives then tried again still a nogo.... it turns on but no post.
Try using just one stick of ram in slots 3 or 4, dont use slots 1 or 2. If one stick works, try both sticks in slots 3 and 4.
tried what u said before u posted it and nothing worked. i took it to frys and it posted for them telling me to come back tomorrow with my cpu and memory to see what was wrong. got home and tried again now its back to normal... i dont know whats going on.
Board working: Yes
Ram Company: Patriot
Ram Model #: PDC22G6400LLK (2)
Ram PCB: ?
Ram IC's: Elpida
Board working: Yes
Ram Company: Kingston
Ram Model #: KVR667D2/1GR, cheapie ValueRAM line
Ram PCB: I see no alphanumeric strings beginning with 'B' anywhere on the PCB--I assume that means it's JEDEC reference? Seems like most people find Kingston doesn't use Brainpower PCBs anyway...
Ram IC's: Again, not much luck IDing the ICs. Marked as Kingston, "D6408TEBGGL3R," pretty squarish. Don't seem to boot above 667@1.8v, playing around with higher clocks at higher VDIMMs now.
Ram Stock Voltage: 1.8V
Ram Voltage as you use it 24/7: 1.8V
Ram Voltage MAX you've used EVER: With the memclock lock I've never tried to push it above 667MHz, so I don't think I've ever bumped the VDIMM. EDIT: Ok, trying higher VDIMMs to see what it can do.
EDIT 2: Needs 1.9v VDIMM to POST and pass Memtest+ at 800 and 5-5-5-15-24; needs 2.1v for 4-4-4-10-20. Needs 2.4v to POST at 1000 5-5-5-15-24, but won't pass Memtest+ even at 2.5v. Downside of absolute memclocks instead of dividers is that I can only run at a menu-provided clock or 1:1 (which is only 667 with my wimpy E4300), and nothing in between.
Guess I'll try running at 2.1v for a bit, see if that kills my board.
Ram Model #:Board working: Yes
Ram Company: SUPER TALENT
Ram Model #:T6UB1GC5
Ram PCB: idk
Ram IC's: idk
Ram Stock Voltage:1.8v
Ram Voltage as you use it 24/7: 1.8v
Ram Voltage MAX you've used EVER: 1.8v
ps, i love this board!!!
Board working: Yes
Ram Company: PNY
Ram Model #: D22GX53OPT
Ram PCB: (PNY is not on the list)
Ram IC's:
Ram Stock Voltage: 1.8v
Ram Voltage MAX you've used EVER: 2.2v
Board working: Yes
Ram Company: PQI
Ram Model #: PQI24200-2GDB (Turbo line)
Ram PCB: Not sure on this here.
Ram IC's: This line is not on the ramlist.. shrug?
Ram Stock Voltage: 2.0
Here you go. Not sure on the chips on the sticks. I just bought it because it was cheap. :D
NOt necessarily, I'm just trying to figure out what the problem is with the boards that are having problems.
D, unless they are all using the same ICs, it looks pretty much all over the map! Could still be problems with the RAM slots or the voltage at startup, however. Maybe it's only giving 1.7? *shrug*
Mine had some serious issues posting the first time. I unplugged the RAM half a dozen times and cleared the CMOS several times. Finally had it working with one stick in either the 1 or 2 slot and clearing it for a few seconds with the power disconnected. I was using the RAM in sig. compwarez has that board now though and he didn't have any issues.
Board working: Yes
Ram Model #: PC2-6400C4 Rev 2.1
Ram PCB: Standard I guess
Ram IC's: ProMOS
Ram Voltage as you use it 24/7: 2.1v (only had the board a few days)
Board working: Yes
Ram Company: GSkill
Ram Model #: F2-6400CL4D-2GBPK
Ram PCB: ProMOS 6-layer PCB (from Ram List)
Ram IC's: ProMOS 6-layer PCB (from Ram List)
Ram Stock Voltage: 1.9-2.0
Ram Voltage as you use it 24/7: 1.7-8 (default MB setting)
Ram Voltage MAX you've used EVER: 1.7-8 (default MB setting)
Board working: No (restarts after finishing loading OS then no post at all), Yes (onboard video bad), Yes (restarts after finishes loading OS)
Ram Company: Teamgroup, Supertalent
Ram Model #: TXDD1024M667HC3 (2 of them), T6UX2GC5
Ram PCB: Brainpower, and JEDEC standard?
Ram IC's: Micron D9, and unsure
Ram Stock Voltage: 1.8 - 2.2, ???
Ram Voltage MAX you've used EVER: 2.4, 2.2
hmmm... from the looks of the component list, you're all hoping it was ram that was to blame?
Board working: #1: Bios Boot Screen for 3 secs, #2 DOA, #3 DOA
Ram Company: Corsair , GSkill
Ram Model #: TWIN2X2048-6400, F2-6400CL5D-2GBNQ, F2-6400PHU2-2GBHZ
Ram PCB: mult
Ram IC's: mult
Ram Stock Voltage: Corsair 1.9, Gskill set #1 1.8-2.0, Gskill set #2 2.0-2.1
Ram Voltage as you use it 24/7: default
Ram Voltage MAX you've used EVER: default
I also tried different hardware configurations on the board. And yes I tried every slot configuration possible every time. I was so sure that I was missing something I actually made a spreadsheet. How sad is that?
CPUs: e6600, QX6700
Video: Onboard, 7600, 7800
PSU: Antec, Corsair, Ultra
Built a second machine for my son with the same board.
Board working: Board works fine
Ram Company: OCZ
Ram Model #: 2x1GB Gold XTC 5-6-6-15
Ram PCB: Brainpower
Ram IC's: D9
Ram Stock Voltage: 2.0-2.1
Ram Voltage as you use it 24/7: running DDR800 4-4-4-10 1.9V
Ram Voltage MAX you've used EVER: 1.9V
Board working: dead, no POST
Ram Company: G. Skill
Ram Model #: 2 sets of F2-6400PHU2-2GBHZ (DDR2-800 4-4-4-12), 4GB total
Ram PCB: see above
Ram IC's: D9
Ram Voltage as you use it 24/7: running DDR2-800 4-4-4-12 2.1V
Ram Voltage MAX you've used EVER: 2.1V
1) this should be a sticky, especially since new people have fried their boards this week and may not have seen this.
2) has anything come of this? inquiring minds want to know!!!
carry on!
Board working: Dead, no POST
Ram PCB:Unsure
Ram IC's: Unsure
Ram Stock Voltage: I only got to play with CPU overclocking, never even got to the RAM portion before BIOS died. So whatever is stock, 1.9?
Ram Voltage as you use it 24/7: See above/stock
Ram Voltage MAX you've used EVER: See above/stock
Board working: Yes
Ram Model #:CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
