Importance of Chipset Drivers?.
macristina
Hi all guys and gals,
I've recently moved into Windows 10 fresh installation and been recently wondering how important is to install Chipset drivers? it really matter gaming performance wise? my actual motherboard is an Asus Sabertooth Z77 with an i7 3770K at 4.2ghz, When I go to the Manufacturer site I found under chipset driver 2 files called: "Intel Management Engine Interface V11.0.0.1155 " which I really don't know what it mean and the other "Intel Chipset V10.1.1.7"
Thanks in advance.
Yes and yes. The drivers are important if you want everything on your system to work right and for the speedy components (usb 3, sata 3, etc) to be as fast as they can be.
Correct drivers are essential for optimal performance. I do a system wide driver check no less than once a month. I haven't had a BSOD in years.
People blame software coding when they experience an issue but they never take the time to check if a driver update will correct the problem.
Always install them. The Intel chipset and IMEI drivers will directly impact I/O performance.
It's a LOT more important if you are running an "older" operating system like Windows 7. Windows 10, still being pretty new, has fairly up-to-date chipset drivers included. I'd still update them either way.
