Import ova error
Modus
I have exported several vm's from xenserver 6.5, when i attempt to deploy them to vsphere I get
Could not parse the document: 'encoding specified in XML declaration is incorrect".
Any of you guys come across this error before?
Sounds like the XML file is missing some information in it. I have seen similar things when trying to move VMs from a P2V using a third party utility. I ended up using the VCenter Standalone Converter.
The converter doesn't support the ova file type which is the format xenserver exported them in
In my case, I used the converter to convert the physical computer I was trying to convert.
I finally got around this, I encountered many other errors along the way. After 3 1/2 days I'm glad its all over now :)
Thanks for letting us know the resolution!
Sorry:D I actually wrote about the whole project extensively on my blog. The short answer is I used various versions of the vCenter converter, in certain situations I installed the vCenter converter on the VM in order to convert it.
Iopoetve is correct. He let the VCenter Converter treat the VM as a physical pc. The converter created the VM vmdk, vmx file, etc. just like importing an OVA file would.
