Immediate Help Needed!
gullyrip
I just finished building this dual monitor setup and I have a problem w/one of the monitors blinking suddenly. Has anyone heard of this problem? I have:
3500+
neo2 plat
1gb gskill le
74gb raptor
evga 6800 ultra
and 2 x 2001fp's
It only happens on the main monitor. So i'm thinking its the card.
ok it seems like it only happens when i'm updating HL2.
you dont need to bumb it that much, it never left the first page...
But check your refresh rates and resoultions, I had problems running dual monitors..make sure there res and rates match, then go up fomr there?
Also what drivers are you useing? Try diffrent drivers..if NVIDIA, install the WDM drivers..might help, not sure why, but it cant hurt.
If NVIDIA try useing there wizard for it when you enable nView...
it would be nice if you answered my question as well.
