Immation Disk Stakka
Silent Assasin
Ok, with my prevoius tigerdirect.com order, they sent me a catalogue and I was browsing through it and saw this thing called the Disk Stakka made by Immation..... From the description, it seemed pretty handy, but on the other hand, after checking it out online, it just seems like a cheap piece of crap.... Anyone have one, or something similiar? I want to know how this works. The housing would definatly need some modding, but if it does what it says it does in a timely matter, it might be worht spending some holiday cash on.... My main concern is that it's like one of those old cheap pieces of crap that actually scans all the disks until it finds what you searched for. Or is it set up so that when you insert a disc, you tell the computer what's on the disc and it keeps it's location in memory so that I can say, do a search for, "FEAR" and it will pop out my FEAR cd within seconds without having to scan through all the cd's... If this is indeed what it does, I may have to buy a couple.
