greggerojr
- Jul 31, 2004
I just installed a PNY 6800 GT into my Dell Poweredge 400SC and I have terrible image quality. Everything looks fuzzy at the resoulution of 1280x1024. I used to have a Radeon 9500 using the Cat 4.7's which I deleted using the ATi Uninstaller Util from Add&Remove. I tried the 61.76 and 61.77 nvidias and both dont solve the problem. The power supply on the 400SC is listed at 250w but many FAQ's in regards to this box list it as a 350w that is conservatively labeled. I did try Star Wars Galaxies with the new card and everything looked good except the fonts again. I would think that a lower wattage power supply would effect the in game performance but it all looked good. Any advice would be helpful.
Thanks,
G
Thanks,
G
