Imac G3's, $67
dude.. this is sweet. Thanks for the link. Fishtank mod anyone? ;) I might pick up 2. One for a fishtank mod, and another just to have a Fisher Price looking PC. :p
Does anyone have any experience setting up any version of Linux on one of these? Perfect computer to run a lan based home theater ...
1. Pull out all components except clear tube from front (so you can see in)
2. Seal all edges/ports to make it water tight.
3. Add water.
4. Add fish.
You've got yourself a dandy fish tank that looks clever.
Before anyone orders, make sure you look at the system's "Refurbished Desktop Grade". Some of them seem to be in pretty bad shape.
Anything can run OS X.....Provided you can install linux on it and get PearPC running..... But seriously, the minimum req for OS X is a G3. And no, it does not run nicely at all.
Dillusion said:
So the 450/400MHZ ones cant run OSX/OS10? :(
They could...but I wouldn't do it without maxing the RAM.
iMacs that are not slot-loading (for CD drive) use SO-DIMM modules, which are a pain; check the maximum RAM (you may be limited to 256-512MB), and they're limited to 66MHz FSB, OS X will be pokey.
Later slot-load CD iMacs use PC-100 SDRAM and have a 100MHz FSB instead of the earlier 66MHz FSB; you should be able to go to a gig of RAM, which ought to make OS X perform adequately. Even then, I'd probably stick with 10.2 (Jaguar) or 10.3 (Panther) and not run Tiger on them.
Actually this was on digg a few days ago, apparently tiger runs smoother than earlier versions, go figure. Would make great internet/kids machines but not much else really.
http://osnews.com/story.php?news_id=15122
I wish I lived closer to Oceanside. I would go pick up a couple. :(
goodcooper said:
will any of these run OSX?
you need a G4 or higher don't you :(
Yes, my G3 400 iMac DV is running OS-x. Though the monitor is hosed, I have to use an external monitor.
Picture tube was a big issue with these things, the newer ones will eventually ditch the CRT... too much trouble for Apple.
OSX will run on a G3 iMac. You have to have at least 256mb of RAM. Though, I'm sure everyone here has a few sticks of PC100 layin' around to fix that.
I put Ubuntu on mine, but you have to remember; no Flash support for Linux on a PPC.
no, actually, I was being pretty serious. :rolleyes:
Good article on using the G3 in 2006.
Review: Going Back to a G3 iMac
A few months ago Thom bought and reviewed an iMac G3 333 Mhz while it was running Mac OS 9. I was always fond of the looks of the classic iMacs. They were just too cute to not want one. Recently Geeks.com restocked their Mac line with refurbished iMac G3s. They sent us one in, a 400 Mhz DV model (first released in October 1999) and we tried out not only Mac OS 9.2.2 but also the latest Mac OS X, v10.4.7. Read more as to how this old good classic iMac G3 performed....
EyeMac G3 LCD - wiring guide
Guide: iMac Conversion
Max Memory:
333Mhz and lower = 512MB
350Mhz and better = 1GB
There are two 350Mhz models that are worth looking at, the third and fourth have C ratings, which is a pretty poor rating.
Apple iMac G3 350MHz 64MB 6GB CD 15" w/OS 9 - A
Apple iMac G3 350MHz 64MB 6GB CD 15" w/OS 9 - B
Apple iMac G3 350MHz 64MB 6GB CD 15" w/OS 9 - C
Apple iMac G3 350MHz 64MB 6GB CD 15" CRT w/OS 8 - C (AQUA)
I got rid of my B&W G3 a few months ago, but it ran OS X 10.3 pretty decently. 10.3 ran better than 10.2. I overclocked the CPU from 350MHz to 400MHz with the FSB/multiplier jumper block and had 416MB memory and a 40GB HD in it. It had a cheesy Rage 128 card but the GUI was very responsive.
The 6GB hard drives that shipped in Macs of that era are really, really slow (no joke at all). Mine originally came with a 6GB Maxtor drive and that was the single component that caused the biggest performance bottleneck. After upgrading to a pretty old Seagate 40GB 5400RPM (ST340810A) drive everything was much faster.
Actually, the part that powered the tube, known as the Power Analog Video board (PAV board by techs) was a major issue on many all-in-one Macs. When I worked on them, the Rev. A-D iMacs didn't have near the problem the slot-loads did, likely because the tray-load models had a fan to cool the iMac's innards. The slot-loads boasted quiet convenction cooling, which meant internal components got hotter, and that part just didn't stand up to heat well. Symptoms included flickering CRT's, or sometimes a yellowish cast to the screen, or sometimes no video at all. I never saw a tube go bad, just the part that delivered power to it.
I hated replacing those. You'd have to make sure the anode for the CRT was discharged with a probe, and while I never encountered a bad one (they were supposed to discharge on their own when powered off, the manual discharge was a precaution only) the thought of poking a grounded wire into an area that could have 15,000 volts never made me comfortable.
LoneWolf (former Apple Certified Tech., among other things)
I put a 40mm fan in the back of my slot load iMac. It made a big difference on the heat in there and made it more stable (wouldn't stay running for more than 24 hours).
Other than a 15" screen and no video out?
Linux is easy on the 350s. I have run Ubuntu on an imac 350 with 256mb of ram and it ran fine. If I remember correctly, on the 333s and under, the boot partition cannot be larger than 8GB or it won't boot. I know my 233 beige G3 desktop does this but I cannot remember the point where that problem disappears.
I ran OS 10.2 on a iMac 333MHz with 192mb of ram. Granted it wasn't overly responsive, but it worked fine.
