hey, i'm currently looking at upgrading my computer because it is freakin ancient!
barton 2500+ OCed, FTL!
anyways,
i have done the research, but i really can't seem to find a motherboard that really works well while staying in my price range.
The things I need to purchase are: motherboard, video card, memory, cpu, and psu.
Below are a list of parts I have searched and are pretty set on buying.
evga 8800gt video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318
Antec earthwatts 500w psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
4gb G. Skill memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Intel Q6600 cpu: http://www.microcenter.com/single_product_results.phtml?product_id=0257938
Motherboard: Here's where I need help the most.
all this comes up to 550+ shipping
I really wanted to stay under 700 so i did not want to spend 150 on the motherboard. I'm looking for something that would have RAID compatibility as well, but it seems that most of them that are RAID compatible are a lot more expensive.
Can anyone suggest other parts that may be cheaper so that I can buy a better a more expensive motherboard, OR can u suggest a motherboard that is reliable/performs well, while staying under a certain budget?
The reason I did not choose to buy cooling solutions is because I am not planning on OCing at all at this point and will purchase later when I do decide I want to. My friend is running an Intel Core2Duo E8400 non OCed with stock fan/heatsink and it runs at 30 degrees, so I'm assuming this CPU would be similar.
If u guys could help me out, it would be MUCHHH appreciated!
anyways,
