I'm upgrading, but I need help.
TeeJay
Hi everyone...
The topic says it all...
Lets start off with my budget, max I can go for is 520$.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Gaming.
500$
3) Where do you live?
Kingdom of Bahrain, the Arabian Gulf.
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
Motherboard, CPU, RAM, PSU.
6) Will you be overclocking?
No
7) What size monitor do you have or plan to have?
Not sure
Whenever I figure out the items I want to buy.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS key/license?
I have lots of things in mind to buy, but lets start off with what I want the most first, then if I have enough budget left, we'll see...
Good Gaming Motherboard?
Good Gaming CPU?
Good PSU?
Those 4 things are the first to consider before buying anything else, other things I want to buy is:
RAM(I have 4x PC2 6400 1GB Dual CH TItanium Series EPP Ready, but if I use all 4 of them they won't work, but if I use 3 they'll work.)
If I need any extra cooling will you please mention that
I'll be using Windows XP Pro SP 3, and obviously I'll be using it for gaming(Counter-Strike: Source, RuneScape, and things like that), I will not\don't want to overclock any of the components...
Any help will be appreciated, thanks in advance
EDIT: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.161238
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.155228
I just took a look at these combo deals, I don't know though, they look great...I need help.
~TeeJay
PSU -$99.99
CPU - $124.99
MOBO - $194.99
Since you are not overclocking, you shouldn't need any additional cooling, though personally I would probably replace the stock CPU cooler with an aftermarket
and the specs of the old pc as well.
BIOSTAR TA760G $80
AMD Phenom II X3 720 2.8GHz $160
BFG Tech LS SERIES LS-550 550W $80
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - Retail $37
$357 From newegg.com before shipping and taxes.
BIOSTAR TA760G $80
MSI K9N SLI Platinum, Athlon 64 FX 62 CPU, 7600GS, Fatal1ty Pro Series Sound Card, 4x OCZ 1GB RAM(But as mentioned above, can't get all 4 to work together, donnu what's wrong, so I use 3), 160GB Hard disk.
EDIT: AMD Phenom II X3 720 2.8GHz isn't supported by BIOSTAR TA760G.
XP can't see the other Gig of ram any ways... So it doesn't really matter, therefore use the other $160 bucks to get a 4850. Either the Asus or Sapphire for $145 from newegg.
Where you read that?
Oh...AM2+ is supposed to mean AM2 and up?
Sorry didn't know that lol ;p I'm a noob in this kind of stuff :p thought AM2+ was a CPU support type :$ Anyway, thanks for the advice, I'll get on reviews and tell you guys :D
lol... PII 720 has both a DDR2 and DDR3 memory controller and will work in a AM2 socket motherboard.
"...supported upcoming AMD Socket AM3+/AM2+ 45nm processors, it delivers better overclocking capabilities and lower power consumption. By the way, AM3 CPU supports both DDR2 /DDR3 memory module and accelerates data transfer rate up to 5200MT/s via HyperTransport 3.0 technology...."
http://www.biostar.com.tw/app/en-us/t-series/introduction.php?S_ID=377
You said a 4850...There are tons of them, I don't know which is the best for me...Can you please show me? :O
With no issues...
Mhm...Problems came now, NewEgg only ships to the US, Canada and China. So I can't buy stuff from it.
So I went to check eBay...I found what I wanted except for the Biostar TA790GX MoBo, do you think there's an another MoBo I can replace with the Biostar TA790GX?
Thanks in advance
~Tj
