I'm stumped...HD dead or not???
Ok here's the story my 20gb western digital 2mb cache harddrive seemed to have died when it suddently failed to show up in "My Computer"
so i said oh well guess i'll go buy a new one. so i did, but then my friend was like let me try it in my computer, so i let him and he took it to his house and the damn thing worked.
so i took it back and put it back in my computer, and tried to boot from it and i got a blue screen of some sort. When it wouldn't boot, i decided to just try to read it from another harddrive it still refused to show up in "My Computer" so i thought maybe it's the cable, so i tried another IDE cable... no help... So i tried another IDE channel (the integrated promise controller).... No help...
could you guys give me some insight???
thanks
ship it to me :D
... download and run the util / diag tools from Western Digital. run the FULL test, not just the short one. if it passes that.. you're likely ok. if it doesn't.. RMA or doorstop. (if it passes and windows is being stoopid.. use the "zero drive" option and reinstall.. (or TRY a "repair" first if you wish.. but reinstalls are not overrated :D )
.. then install Folding@Home.
sharp
try a different ide cable
*EDIT*oops dangit, me and not reading everything, sorry scratch this.
alright i'll try that as soon as i have some free time, and i can't rma the harddrive is like 4 years old
Ok i'll try that too what is the voltage i should be looking at 5V or 12V
but i already have 2 80gigs in there and it's working fine...and when i tried the dead one i unplugged one of them and one of my cd drives
This same thing happened to me a while back. I got it fixed but at the time can't really remember what I did. Let me think about it for a few minutes and go over my computer to see if it helps my memory.
Does your hard drive show up in disk management?
1. Right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Disk Management.
I remember a friend with a WD hd having a virus which wiped a hidden sector on disk making windows unable to "see" the disk, which worked fine using a windows98 boot disk...odd...
Zerofilling the disk got it back on action :p
OldMX
i'll see when i get home...i'm going to classes now
ok i think it's fixed....
all i had to do was go to device manager and enable the damn thing...
for some reason it was disabled...so yea it's fixed
i was on my way to disk mangement to see if it was there but i think i remembered that it didn't show up because i remembered looking there before
thanks for all your help everyone
Cool,
Congrats on getting it working. It is a good thing I didn't recomend fdisking it. ;)
