I'm lazy so I'm asking you.
JackieO
Hola - first of all, what's up with the forum? All the old data seems to be lost, I had to re-reg my nick! Blasphemy!
Second, I want to make a SFF comp as an HTPC, so basically it needs to have a half decent video card that will do HD (through DVI) and will achieve reasonable 1280x980 fps, a sound card that will decode EAX/2.0/3.0 and has an SPDIF for output to a receiver for DD and DTS decoding, and above all it needs to be quiet. I am fine with Intel or AMD, I know both are able to do what I want them to but I'd rather go whichever one I am able to keep quieter. Budget is not really a concern.
Thanks in advance for suggestions/comments/flames.
-JackieO
So as far as I can tell if I want the coolest (and therefore quietest) system, I should look at Northwood CPUs. Does anyone feel this is in error? It seems to me that generally AMD processors and Prescott processors run about 10-15 degrees warmer. Now I have to decide which case to go for. I've been reading a lot about the Aria and the Shuttle cases but it seems like there is no concensus on which SFF case is generally the coolest/quietest (or the best tradeoff of both). I should mention I'm not totally adverse to modding the case, but I'd rather not if at all possible. Also, the motherboard situation is a little confusing. I've been away long enough that I'm pretty ignorant about the chipsets that are currently available for Northwood processor, so any thoughts on that would be appreciated.
Can anyone point me in a direction to do some more reading?
Thanks,
- JackieO
hmm a mobille cheap would be great quiet cool less bvoltage etc...
Hey JackieO. I use an Antec Aria with an Asus P4P800-VM motherboard. I am running a 3.2 P4 Northwood. I am water cooling my cpu so it stays around the 32c at idle. I did put one 80mm hole in each side of my case to help air flow. I modded the case right from the start so I can't say what a stock case really does.
Hope this helps.
My Antec Aria
Thanks for the replies. I considered watercooling and still am, but of course would like to stick with fans if at all possible. I am not going to overclock so if I can keep the CPU under 55 degrees at load I think I should be fine. The real kicker seems to be finding fans that will keep the processor/video card cool and not sound like a vacuum cleaner. Ah, the eternal struggle of modern computers. I am going to order one of those ARIA's and see how it goes, now I just have to find a motherboard/soundcard/video card. Well, shopping is the fun part at least. :)
Just for reference JackieO, I am running a 9800XT,Hercules Fortissimo7.1, 1gig of PC-3200 and the rest I stated before. It has been working great so far!
get a mobile athlon xp 2400+ (35 watt) or 2600+ (45 watt) if you want minimal cooling
Damn that's a really good (and painfully obvious) idea. Why didn't I think of that? Do those work in regular Barton ready motherboards? If so, I think I am set!
yeah they do BUT most small form factors won't let you change the multipler via bios and you'll need to do the wire trick....(or well pretty much any biostar ideq at least).....but i have my amd xp mobile 2200+ (35watt) running stable at 2.08ghz on stock multipler. AIM has been up for 8+ days so far. :) And I've even ran multiple 3d games at once by accident and everything was fine. Temp is about 48c with fans on 100% (which i can't hear) or about 54c on auto settings (which is normally 20% of their speed) under full loads. Compare that to a 70c p4 ;)
Wait - the multiplier thing is only if I intend on overclocking it right? I may or may not do that so if that's the case I am not too worried. Any motherboard recommendations?
the stock multipler on a xp-m is 6x....so they run at 800mhz out of the box if you can't adjust the multipler from bios....regardless of what mobile you buy...they all run 6x133 out of the box...the MOST i got out of that 6x multipler (before i found out how to do the wiretrick from these forums) was 1.28ghz or something...that was like a bit over 204fsb mad overclock on the cheap ram i was using
and once i did the wiretrick i got it to the stock 12.5 multipler and it ran perfectly even overclocked to 2.08ghz on a single 512mb of crucial ddr400 (set the fsb from 133 to 166 via the jumper on the board).
i cant recall any sff that have multipler settings in bios except maybe the ones using an nforce2 chipset? and those are quite a bit more expensive than my 200v.
Ah ok, thanks for the information. I'll make sure to get a board with multipliers if I get the -M.
