I'm kind of stumped...
HitMan-sC
Well, I built the system in my sig about a week or two ago, but it turns out the memory was bad. The new memory just came from newegg, and after installing and trying to get to boot from a CD or floppy - nothing will happen. The boot order is floppy, cd-rom, hard-drive. The system posts fine, but it just gets to a black screen with a blinking cursor. The system booted from CD/floppy fine when I ran it with the bad memory! I tried booting with a blank floppy, putting the Windows XP CD in my CD drive, removing the floppy, and then booting and still the same thing. I have built systems before, but I have never felt this stupid. Is there something about this particular motherboard/chipset that I should know? :p I'm such a dumbass.
It sounds like it has something to do with the BIOS....maybe something with the IDE configs or SATA configs. It sounds like it has trouble moving to the next step after the post. You could also try clearing the CMOS and trying again.
I've cleared the CMOS three times. It loads the defaults, and then when I reboot it does the same thing. I tried a different floppy, too. Even when I try to boot from the XP CD, it goes right to the SATA Raid config screen......anything?
It should be going to the RAID config screen before trying to boot from the XP CD. Assuming your RAID controller is enabled in the BIOS, of course.
Yup, and if I disable the RAID controller, after posting, it just comes to a blank screen with a blinking cursor. This is really frustrating the hell out of me.
I had the same issue when I first installed my hitachi drives on the ich5r in raid 0
After exhausting every other possibility i did two things. (not sure which resolved , and i wont know until next time i go clean install)
1.) I dropped the stripe size down from 128 to 64
2.) on the f6 prompt for the raid controller driver (created disc from the create disc utiliity in the intell app accelerator folder on the mobo disc on antoher machine) I told the rig i had two devices and hit enter twice, it loaded the driver both times and bang things booted and xp install went without a hitch
I'm not using a RAID array, though. And if I just let it sit there at the Silicon Image SATA RAID screen, if I press F4 or CTRL + S, it doesn't respond at all.
did you load the raid controller driver anyway? IF not you may have to
Your mobo dic there should be a driver , explore the disc on another mahcine or download it somewhere .it needs to be on a floppy. Funny how a legacy device is still needed to load xp using thrid party controlers
Anyway when xp prompts you to press f6 during setup you hit f6
then load the flopy in the drive and follow gui instructions
I am not familiar with ath board but i suspectyoushoudl have the controller driver loaded irrespective of whether you use it and it will come in handy in the event yougo raid later. You have nothing to loose. OR is it that you cant even get to xp setup?
as far as raid array set up it would be control H, I or mybe S depends on mobo manual
I can't get to anything. I can't even boot from a floppy. Everything posts fine, but I can't boot from any device.
Jumper configuration on the mobo?
You know its something stupid, walk away , have a beer and stew on it
Ok, well, I unplugged my raptor, and viola, everything can boot perfectly. With it plugged in, however, I get that hanging screen. It seems like a common problem on the boards. I called their tech support and all I got was a cocky jerk. Oh well...if any of you have experience with this board, please, help a guy out. I'd greatly appreciate it.
Problem solved
Great, now everything works great, but I can't get it to recognize my raptor! Lol....going with the Asus board would probably have saved me hours of headache. I'll have to take that into consideration next time....
You will be asimilated ;)
PS: How the hell do you spell asimilated as in "The Borg"
