Specs:
| Sapphire Radeon X800 XT | A64 3500+ (Winchester) |
| 1 Gig Cosiar XSM PC3200 | MSI Neo2 Platinum |
| Samsung 160 gig SATA HDD | NEC 3500A dual layer DVD |
| NEC MultiSync FE991SB 19'' Monitor | 3DMark 05 Score: 5658 |
I was just playing KOTOR on 8xAF/2xAA and I was getting 40 and 30 frames per second. Now last week I was playing KOTOR with everything in the control panel at max and I was getting 40-50. So I go back into the control panel put the Catalyst AI on the highest settings, turn TRUFORM on, put it on 16xAF/6xAA it doesn't run well still in the 40's but it runs better than when it was on the lower settings. What the hell is going on? I play my games on 1600x1200 resolution. Nothing seems to help the FPS in WoW also. I don't know what I should do. Should I call Sapphire and tell them to send me a new one? My temps are fine and my rails are in range.
Also could something be wrong with FRAPS I mean when it says my frames are in the 30's I don't see it for KOTOR. However, when it says it for WoW I can see it.
