I'm confused about the SATA interface.
Zap [PCGO]
Hello, I'm trying to put together a nice system. I picked this motherboard over by Newegg.com
http://www.newegg.com/Product/Product.asp?Item=N82E16813152049
My question is: Which type of HDs will work with those "SATA II" interface as described in the mobo's description?
I got confused because when I went to look for HDs, the interface options shows up for SATAs are: "Serial ATA150" and "SATA 3.0Gb/s"
My guess is that the Chaintech mobo is refering to the latter of the two options.( the SATA 3.0Gb/s one) However, I'm not too sure, so I'm asking you guys for some confirmation or maybe you guys can tell me something better as an option for HD interface.
I'm planning to run one HD of at least 160GB and a DVD burner. Since we're on the topic, is there a DVD burner out there that utilize the same SATA interface as that of the one that Chaintech mobo supports?
much appreciated
Well the best place for information is directly from the source, the SATA+IO standards body (SATA+IO is now the correct offical name for the next standard rather than SATA II).
http://www.sata-io.org/
To help explain and to also dispel some incorrect assumptions that SATA II means 3Gb/s is this link. http://www.sata-io.org/namingguidelines.asp
Remember the different standards for IDE? Ultra-DMA, 100 and then 133? The SATA standards are similar to that.
If you purchase a newer motherboard that has "SATA II" ports that are SATA-IO with 3Gb/s capabilities, it will also work with the older 1.5Gb/s drives as well. SATA-IO 3Gb/s drives may not function correctly with the older 1.5Gb/s controller however. Hitachi worked arround this problem by having the end user running a firmware update if they wanted the full 3Gb/s function with their newer drives, having them default to the older standard by default.
The Chaintech motherboard is using the nForce4 Ultra chipset, that has "SATA II" ports that are actually SATA-IO 3Gb/s capable ports that also offer additional extended SATA features, like NCQ tagging, etc. So the nForce4 Ultra chipset will work with "all" current SATA products currently available and also supports features that may not yet have been implemented in consumer drives.
